Toyota Sequoia Wall Build
Sequoia_Bass
this is how i play to do the ports. attatch them to a peoce of wood. that is mounted onto box. this way i can interchange ports if i wanted
I am wanting to mount the amps right behind the b pillar. where the second doors are. this way i will have easy acess to them and also the power wire runs will be shorter. and the speaker wire runs will also be shorter.less wire less money! less wire also means less resistance!! going to do all of the amps on the driver side and mount cross overs and other processors on the passenger side behind be pillar.
Thats an idea....anyone ever make their own aero ports out of fiberglass? Could use a big ass stirofoam block or something and shape it to what u need then cover it to protect from resin then glass the shape.
9 hours ago, Sequoia_Bass said:
Ah alright. Going to do sono tube. And will most likely fiber glass it or use resin. just something to give it strength
If you want to resin/fiberglass the sono tube, it certainly won't hurt, but it shouldn't be needed.  That thing is meant to hold over 600 lbs of concrete, they are a LOT stronger than people think.  You just want to be sure you support it at both ends.
One way to get a flare on them is to glue the ends to some plywood/MDF rings.  Its best if you cut a slot in the ring to glue to (circle jig works well).  You can then use as large of a roundover bit as you can get to cut a flare in the ring.
Builds:
Alright i wont fiber glass them. And good Idea with the wood rings!.
p.s: I plan to have all of this build done by the end of summer but hoping to start on it soon. just wanting to grt a plan first then build
  • 1 month later...
I Installed a pioneer MVH-X690BS double din headunit. So that is another part of build finished. I am loving the headunit. The colors are vibrant and bright.I love all of the functions. The bluetooth works perfectly and i've had no problems with the headunit.
Instead of using 6 soundqubed hds215s i'm going to use 6 PSI Platform 1 15s with HP option. This has nothing to do with quality or brand of either sub. It's just that i already have 3 of the 6 PSI's. Will still be using the american bass PH4000MD amps, One amp per sub.
Is 24 cubic feet and 2 14 inch aero ports still good for the psi's?
Well i do not think i'll be able to flat wall 6 15s. the space i have to work with is. 48 inches wide gross 39 inches high gross and up to 75 inches long
but box is double layer 3/4 birch so 45inches wide and 36 inches wide net. So i might do either 4 15s flat wall or 6 15s 4th order. only have enough space to do a 2.5:1 ratio i think.
  • Who's Online   0 Members, 0 Anonymous, 2223 Guests (See full list)
