Chris Stanley Posted February 4, 2017 Report Posted February 4, 2017 I am stuck on a Design for a 2 Soundqubed HDS215's... vehicle is a 2005 honda pilot, max dimensions are roughtly 19Hx42Wx26D and would prefer 4th Order or Ported, any help appreciated
ShadeTreeMechanic Posted February 4, 2017 Report Posted February 4, 2017 Welcome to SMD! How much power are you going to run? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Chris Stanley Posted February 5, 2017 Author Report Posted February 5, 2017 Sorry for late reply, 1200w is the plan
teardrop Posted February 5, 2017 Report Posted February 5, 2017 might not have enuf room for a 4th order box
Chris Stanley Posted February 6, 2017 Author Report Posted February 6, 2017 figured i wouldnt have enough room for a 4th, just thought itd be cool to build one if space was permitting after all
Kraken Posted February 6, 2017 Report Posted February 6, 2017 Your best bet would be a ported box for those. How much airspace/what tuning freq are you going for? Alpine cde143bt/ Alpine ktp445u (4x45 amp) 2 Crescendo STS 1 (on alpine 4x45 on 2 channel mode) 4 Crescendo pwx 6.5's in front doors (Skar RP150.4) 1 Sundown zv3 12, SAE1500D. Box is 2.5 cubes tuned to 30hz.
Chris Stanley Posted February 6, 2017 Author Report Posted February 6, 2017 i would prefer somewhere around 30-32 hz for tuning
