Jessica Posted February 19, 2017 Report Posted February 19, 2017 i never charge my batteries. ok, maybe once in a blue moon. if my resting voltage is above 12.6 i dont care. if you compete and are looking for that .1db go ahead. most every bettery will last 5 years if your alt is working. thats just me. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
BassMunky Posted February 20, 2017 Author Report Posted February 20, 2017 My rest voltage is usually 12.5 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted February 20, 2017 Author Report Posted February 20, 2017 Bumper...... Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted February 22, 2017 Author Report Posted February 22, 2017 Just got it today it say it has desulphation mode. So how do I get to that mode. Or does it automatically pick it? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted February 22, 2017 Author Report Posted February 22, 2017 On February 11, 2017 at 4:22 PM, reedal said: I don't know if the Schumacher does. The CTEK 7002 does. It's what I have. You just set it to recondition (super easy, just plug it in and push the button until recond. Lights up) and then it assesses where your battery is at. If it needs it, it will start the process. If not, it gives it a float charge until you take the charger off of the battery. It say it detect if it has to be desulphated and desulphated it. Idk how it knows. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted February 24, 2017 Author Report Posted February 24, 2017 also why wont my lead acid battery go in float mode when it says it 100% charged? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted February 25, 2017 Author Report Posted February 25, 2017 Bump bump bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
reedal Posted February 25, 2017 Report Posted February 25, 2017 On 2/24/2017 at 1:26 AM, BassMunky said: also why wont my lead acid battery go in float mode when it says it 100% charged? Maybe what you're using doesn't have a trickle/float charge mode. Not all chargers are created equal. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
BassMunky Posted February 27, 2017 Author Report Posted February 27, 2017 Yes it does. Also how long you guy leave it on the float mode? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted February 28, 2017 Author Report Posted February 28, 2017 Yes it does. Also how long you guy leave it on the float mode? bumpppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
