*HELP* I made a boo boo
so ive been getting more and more into the tech side of things lately. well i made some changed and now have some problems that didnt happen right away.
heres what i did the last few days
-redid the wiring inside and moved some fans around
-changed sata mode to achi instead of ide
-enabled samsung rapid mode
-disabled samsung rapid mode because it kept causing a bsod
-modified dram timings and other small bios settings
issue- today at boot it went right into a recovery loop. fixed that, somehow it changed the boot device. so i fixed that. once that loaded it crashed for smasung raper error. ok got it stable enough to disbale that and reboot. bsod aagin for memory management. reset the RAM timings to stock. finally loaded and everyhting.
no LAN connection... it is giving a Ethernet cable unplugged error. cable should be good. i was playing bf1 and bf4 for a few hours last night till about 2am and this is all going on at 8am. so what could it be? i just restored bios to defualt settings and making only the smallest changes like boost speeds and achi mode and boot devices.
think the lan issue could be driver? bad cable? fried port? what? i just need some help guys. this is starting to be a real pain... i wanna learn tho.
system specs-
mobo- asrock 970 extreme3
cpu- amd fx8350 8 core
gpu- sapphire rx 480 8gb (Am i killing the performance of this having it in a 4x pcie slot?)
psu- corsair ax860i
cooling- corsair h80i gt
ram- corsair venegence lp 16gb dual channel 1866mhz 2 x8gb
boot- samsung 850 evo split to boot and storage
storage 1- adata sx600 ssd 64gb
storage 2- seagate 500gb hdd 7200rpm
network- netgear ac1200 r6220 router, cat6 cable, isp provided modem
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
sounds like you should actually remove items and try again... only 1 (boot) drive... then start playing with the memory chips
system specs-
psu- corsair ax860i
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
the boots are all good now. its the LAN im havinbg a problem with. done everyhting but cany get a connection to establish
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
ill try that next. i didnt know what option was going to be best. my final idea is a restore and do everything clean since folders are so messed up and so many copies. drivers probably got deleted or corrupted somewhere but who knows where. if i do a repair which option do u think is best? just repair the problem or a rollback?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
ended up taking it to the shop. got to the point this morning where it wouldnt boot at all. looks like a fresh install is due. i had win 10. well it wanted to only boot to win 7 and it couldnt find my drives. i took it to the shop and they told it me it was a problem child when i looked it back up. good thing diagnostics were free. thats the hard part now. ill just let them do it and save myself the headache. they had good reviews and this is a new place that isnt my normal repair shop. so i hope all works out. thanks for trying to help guys. seems like it only got worse by sitting there tho. never did get the network issue fixed.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • 1 year later...
Sooo when you switched from IDE, to AHCI you messed up BCD, which is what tells windows what to boot from.
Never use system restore.  In fact, disable it.
Also DRAM timings are a huge bitch and almost never improve anything ever.  Make sure your voltage is right and you'll be fine.
Re-install windows.  Make sure your SATA is in RAID mode so you can use rapidstart.
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
