Andrew Storlie Posted March 9, 2017 Report Posted March 9, 2017 just wanna get a double check on a box im gonna build soon. 2-15" HDC4 subs 8.5 cubes after port and sub dispacment 3-6" ports 26" long each tuned at 30hz will run a sq4500d on the pair box will be 39" wide, 16" tall, 33" deep made from .75 birch with internal reinforcements
Joe X Posted March 9, 2017 Report Posted March 9, 2017 Your port area is rather low, you may be hitting above 30 m/s at higher power.
fyerbyrd22 Posted March 9, 2017 Report Posted March 9, 2017 specs looks fine..port area is not low, should be right at a solid spot actually, considering youre using aeros personal build in progress http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/ www.facebook.com/TurbulentDesigns
99blazer Posted March 9, 2017 Report Posted March 9, 2017 I would email soundqubed and ask. Travis that works there is very knowledgeable. When I was building a box for an hdc4 12 they told me a 6inch aero isn't enough for it due the motorforce of the dc4 08 Ford F150
fyerbyrd22 Posted March 9, 2017 Report Posted March 9, 2017 he has 3 6" aeros, not 1...85sq of port personal build in progress http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/ www.facebook.com/TurbulentDesigns
99blazer Posted March 9, 2017 Report Posted March 9, 2017 Really........ I can read. all I am saying is they said a single 6 isn't even enough for a single 12. and With his specs his box is sitting at 7.8 cubes with sub and port displacements. Thats with out any bracing 08 Ford F150
ShadeTreeMechanic Posted March 9, 2017 Report Posted March 9, 2017 Sure it will do something. But like Joe x said, the port velocity will be high at full power which will cause port compression and a decline in output from the ports. You need more port if you want to get everything you can out of it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
fyerbyrd22 Posted March 9, 2017 Report Posted March 9, 2017 well whoever you spoke to is an idiot...a single 6" aero will work fine for a 12", actually for most drivers that will actually be too much...dont let my post count on here fool you like im some noob...this is what i do...literally (www.facebook.com/TurbulentDesigns) and shadetree, how are u coming up with that answer? show your work personal build in progress http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/ www.facebook.com/TurbulentDesigns
99blazer Posted March 9, 2017 Report Posted March 9, 2017 actually joe x and the soundqubed guys explained it to me really well. If you're to ignorant to comprehend what is trying to be explained that is your problem. 08 Ford F150
fyerbyrd22 Posted March 9, 2017 Report Posted March 9, 2017 OK lol...so what would you do then? and can you explain WHY? personal build in progress http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/ www.facebook.com/TurbulentDesigns
