Chrismctee89 Posted March 17, 2017 Report Share Posted March 17, 2017 So this will be my first major build requiring upgrades to my electrical system and I'm needing some advice/suggestions. I will be running a Fi SP4 v2 dual 2ohm 12" wired to 1ohm on a Soundqubed Q1-4500D.1. Enclosure will be between 3-3.5 cubes tuned to 28hz with 46-52sq. In. Of slot port area. This is in a 2006 Lexus GS300 AWD by the way, But I'm wondering if a 240amp H/O alternator will be sufficient along with an XS battery under the hood and a big XS or two small XS batts in the back will be sufficient so I don't have crazy oltage drop. Oh and I will be listening primarily to rap/hip-hop and will be a daily driver. Money is no object. Just looking for some input on if I'm on the right track from some seasoned bass heads. Thanks in advance! Link to comment Share on other sites More sharing options...
06RTCharger Posted March 17, 2017 Report Share Posted March 17, 2017 Ive no experience, but when i see Lexus GS300 and moneys no object. My first thought was "lithium xs15k would be cool to see". Ever considered goin the lithium route? Save u a ton of weight for that lexus. Just tossin you another idea to consider and check out. I have no experience but i plan on using a lithium when i get my build goin. Link to comment Share on other sites More sharing options...
Chrismctee89 Posted March 17, 2017 Author Report Share Posted March 17, 2017 That's definitely a possibility but I'm gonna ask around about people's personal experience with the lithium batteries before pulling the trigger and dropping $1700 on a battery even when money isn't an object. Thanks for the suggestion and It is intriguing so I will definitely do some research and see what's up. Link to comment Share on other sites More sharing options...
06RTCharger Posted March 18, 2017 Report Share Posted March 18, 2017 Yup definatly do ur own research with any suggestions people give you. Just to be sure its something you actually want and that its quality products. Theres other brands also. Link to comment Share on other sites More sharing options...
8ten8 Posted March 18, 2017 Report Share Posted March 18, 2017 The biggest alt you can fit and about 400Ah of reserve. She'll get down mean Link to comment Share on other sites More sharing options...
Chrismctee89 Posted March 18, 2017 Author Report Share Posted March 18, 2017 The biggest alt I could find that fits my car is a mechman 240 amp. But I heard there's some company that makes them custom for you and to fit in your car? So I might check that out but I definitely want to make sure I have my electrical setup right before I do the install. Thanks for the advice. Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted March 18, 2017 Report Share Posted March 18, 2017 Yea a 240 will be enough. And with just one of those XS15k's you will probably never see below 13 volts. Just make sure you do at least 2 runs of decent ofc 1/0 for power and ground. Link to comment Share on other sites More sharing options...
Chrismctee89 Posted March 18, 2017 Author Report Share Posted March 18, 2017 2 hours ago, Wasteland_Audio said: Yea a 240 will be enough. And with just one of those XS15k's you will probably never see below 13 volts. Just make sure you do at least 2 runs of decent ofc 1/0 for power and ground. Okay cool! But yea I already planned on doing 2 runs with 1/0 gauge knukonceptz kolossus fleks. Link to comment Share on other sites More sharing options...
