WalledSonic Posted April 27, 2017 Report Posted April 27, 2017 I read an SQ post on another forum concerning grounding. That was one of the things mentioned that could introduce noise, but in practice, I dont know if it really matters. Results may vary, I guess. Haha Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
8ten8 Posted April 27, 2017 Author Report Posted April 27, 2017 1 minute ago, WalledSonic said: Directly back to battery ground. Battery ground is the truest ground. Its the voltage source. You mean back to the negative terminal on the front battery? Or directly to one of the grounds on the block or chassis I have running from the negative post?
WalledSonic Posted April 27, 2017 Report Posted April 27, 2017 If you're concerned about noise, back to the battery terminal. But depending on your vehicle, you may not have any noticeable noise so chassis grounding may be great, which is in line with what strangeduck was saying. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
8ten8 Posted April 27, 2017 Author Report Posted April 27, 2017 7 minutes ago, WalledSonic said: If you're concerned about noise, back to the battery terminal. But depending on your vehicle, you may not have any noticeable noise so chassis grounding may be great, which is in line with what strangeduck was saying. Gotcha. Thanks for taking time out to point the way.
WalledSonic Posted April 27, 2017 Report Posted April 27, 2017 Alphablazer is a good example of a rig that has all the grounds ran thru the frame rail. Check out their build log. +163dB rig and I dont think he has problems. But thats not SQ either. And neither is a 5k. Haha Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
8ten8 Posted April 27, 2017 Author Report Posted April 27, 2017 7 minutes ago, WalledSonic said: Alphablazer is a good example of a rig that has all the grounds ran thru the frame rail. Check out their build log. +163dB rig and I dont think he has problems. But thats not SQ either. And neither is a 5k. Haha Yeah, 10-4. That Alphablazer is a mean machine. Didn't know he had a build log here...thanks
