8ten8 Posted April 25, 2017 Report Posted April 25, 2017 How R you achieving your 5K goal? i.e. alt, batts/ah, grounds, power runs, etc. Include your voltage @ full tilt
WalledSonic Posted April 25, 2017 Report Posted April 25, 2017 Singer 240A alt, 215A warm at 2500RPM, 130A at idle. 395Ah XS AGM Dual runs of power and ground to the rear bank Rear bank all bussed in (4) 15's on a Sundown SCV-6000D at 0.7ohm (ran the 6K for a week before I started breaking the windshield so am running low power right now) Dipped into 11s at idle but full tilt at 2500RPM didnt go below 12.0V. I am on the edge of acceptability, IMO. If I had 250A at idle, I'd be happy! Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ShadeTreeMechanic Posted April 25, 2017 Report Posted April 25, 2017 I have an FSD 5k on two hds315 at .5 ohms 250a alternator 2/0 two g31 and g65 up front. Driving down the road I can play about 4 songs and it's in the low 13s. I turn it down to charge back up. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
hdorre Posted April 25, 2017 Report Posted April 25, 2017 My old amp was clamping just over 5k. Singer 250, D2700 up front, 3 G31s in back. Mid/high 12s revved and mid/low 12s at idle. Basically, Id hit a wall once I dropped into reserve. Singer clamped 255A revved and 180 it idle out of it, for what its worth. Edit: That "5k" clamped didnt include the 1500wrms on my frontstage. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
8ten8 Posted April 25, 2017 Author Report Posted April 25, 2017 Thanks gents, that's the kind of info I was looking for. Anybody else who's got 5k experience, bring it on. So far, looks like I need another 175-200ah.
Ron36 Posted April 25, 2017 Report Posted April 25, 2017 I'm running about 4300 RMS and got a 250H.O ALT and 6 batteries, running at .7ohms and don't ever drop below 12.9volts . That's with 1 run to the rear batteries but I just bought all new wire and fuses to do two more runs to the rear . 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Masterbasser Posted April 26, 2017 Report Posted April 26, 2017 I ran a 5k at .7 ohms on a mechman 320 and 3 g 31s and it was overkill, prolly woulda been fine on 1 -2 batteries should add my car was idling around 1200 rpms at the time prolly makes a big difference on alt output Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
8ten8 Posted April 26, 2017 Author Report Posted April 26, 2017 How many positive runs did you have going to the rear? Chassis grounds or runs from front to back?
Ron36 Posted April 26, 2017 Report Posted April 26, 2017 Grounds are grounds don't need to run them from frt batt to rear batt, 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
omg_spoon Posted April 26, 2017 Report Posted April 26, 2017 i used to run 5k on a 320a alt, a d3400 and 2 d3100s voltage would get to about 12 2 runs front to back 98 Mustang GTSinger 3202 12" Incriminator Death Penalties1 SAZ-2500dv22 D3100,1 D34002 Crescendo CZ-65SAX-100.2Door panels by Diablo Kustomz
