Rockford Silver T2 12" Box help
krazz619
So here is another suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
thank you both for all the info. gonna have to go over everything again. I dont trust my max dimensions, and I see how big of a box I need now. im not sure if I can go 20 depth+15height. i can go taller but then ill have to go smaller depth, so just gotta keep playing with it. should i tune around 33hz? and how bad is it if I can't get it into a big enough box?
Joe X you helped me build my last box for Soundqubed HDS212 and HDS312, thanks again!
2015 Scion tC
DieHard AGM Battery, Stock Alternator, with Big 3
Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials
Rockford Fosgate T2D215
Skar RP-1500.1D and RP-150.4AB
Any chance we can make the height 14"? Or 18"x18" H"D?
2015 Scion tC
  • Who's Online   0 Members, 0 Anonymous, 3810 Guests (See full list)
