Connorcerase Posted May 9, 2017 Report Posted May 9, 2017 I have a 00 silverado ext cab looking at 2 boxes for under the back seat both boxes are 1.83 cubes ported. So 2 12"s or 4 10"s (scv2000) I thought the box sounded a little small for 4 10"s but what do you guys think
8ten8 Posted May 9, 2017 Report Posted May 9, 2017 I think you get more cone area with 4 10's. Check the t/s specifications, will be under SD
Kyblack76 Posted May 9, 2017 Report Posted May 9, 2017 1.8 cubes total!?!? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ShadeTreeMechanic Posted May 9, 2017 Report Posted May 9, 2017 ported or sealed? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Connorcerase Posted May 11, 2017 Author Report Posted May 11, 2017 The box goes under the seat which sucks I would take then out if I had the choice but I was thinking if I tuned the port right I might be able to get loud... ish
