Some simple back of the envelope calculations:
Let's assume 360 amp alternators, at 15v.
360amps * 4 Alternators = 1,440 amps.
1,440 amps * 15volts = 21,600w
22kw is roughly 30horsepower.
So, being extremely generous here, if all four alternators were operating at full load, you should see 30-40horsepower load on your engine.
For comparison, your A/C compressor might be putting a load of 10-20horsepower (Depending on the size)
"1 ton cooling power =12k btu/h
If it is a two tone unit then it draws 24k btu/h of energy.
1 ton=12k btu/h
1 hp=2,544 btu/hr
therefore for a 2 ton unit it draws 12k/2544=9.4 HP
3 ton unit 36k/2544=14 HP
There are also mechanical losses as well such as noise, heat& belt on top of that.
I did not include the power drawn by the fan either."- Caspiam M, in a forum post located here: (https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1944982)
So, if you are driving a small 4cyl engine, with A/C and 4 alts at full tilt, it might make it really sluggish to get up to speed, but with a truck/SUV large enough to mount quad alt's, you really shouldn't notice much if any decrease in performance.
yep I'm curious as well getting ready to order a quad bracket in 2007 gmc Yukon xl myself. I have ehard stories of quads stalling engines
I would like to add ive had issues myself with 180 degrees of belt wrap on a mechman 320 in a 6 rib serpentine config.... belt slip ect. top of line belt have been lasting half a year or more though
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
  • Who's Online   0 Members, 0 Anonymous, 4069 Guests (See full list)
