On 6/28/2017 at 2:43 PM, x infektid x said:
eye say ground loop. issue.  ground your outside rca cable to a KNOWN ground source and then try it.. . also . interference can come In from the antenna cable ..  disconnect that and see whathappens
Do not ground your RCAs.  It bypasses the internal filter on the head unit, introducing more noise.
IG @walledsonic
i did the rca ground the nosie was the same but then it sounded weird like it had no punch to it so I took it off and sounded better
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
