Wow I'm seeing a lot of uneducated posts in here. Somebody needs to by a clamp meter and learn to do some real math. I've clamped my Sundowns and seen 320a of current draw without blowing the 160amps worth of fuses. Fuses can take bursts for more than their rating without blowing. Anytime you calculate an amps actual output using its input #s you must calculate efficiency. You find out efficiency by clamping the amplifier, getting the real input and output #s, and then doing the math. Average efficiency for class d amplifiers @ 1ohm is around 70%. I know this because I've actually tested different amplifiers and calculated the results. All the guessing in here is a waste.
Just because youve tested amps at that dosent mean thats the average.
And i never said i would find out how efficent it is and im still not going to agree with the fuse thing because its anywhere from true.
I was giving him a rough estimate of stuf idk if you missed that somewhere or not.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
Honestly i wouldnt go by that chart for anything. The new hybrid amps are blowing all laws that thing is geared on.
But for your amp yes that is right.
How so?
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
How so?
i'm wondering the same thing. it's proper math done to give the results...and even so...it's a 'rough estimate' to go by.
Because there using the hybrid design same as cars, ask steve i remember him explaining something about them and why there fuses dont match the power it puts out.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
the kicker warhorse, the 15k rockford.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
There was something on the rockfords forums about it but there site is down right now. (atleast for me)
Amp- Us-Amps M2D2
Have you had enough
I will be the one
OK.
But who is running them?
Being apart of his site i figured you would know that steve has the rockford 15k.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
