4th order help 2 12" crescendo contralto
I'm trying to design a 4th order for my Dodge charger, but I'm not familiar with bassbox pro. Just wondering how everything looks. I found a design on here that was almost exactly what I needed, but not enough space on vented side so I did a little tweaking. Going for 45-50hz with 2 cubes on sealed and 4 for ported side, for a 2:1 ratio. Not everything is filled in, like fb or f3, but just wondering if it seems solid. I couldn't put the contraltos in as drivers so that it will tell me everything, cause I couldn't get the driver list to update, it kept having an error.
How much power are you going to be running?
I avoid using "ratios" for bandpass box design because they give very inconsistent results.
What kind of usable bandwidth do you want to get?
Builds:
Subs are 2000rms each, and I'll be putting 4500rms on them, and maybe 5500 in future if I want to try to push then a little further. As for bandwith, I want to be able to dip down into the 20s but up to 50s and 60s too hopefully. And yes, I had port area at about 15 per square foot, but I had to tweak it a little bit, now it's dropped down to a little over 12. It's only at 55 sq in of port now.
Those subs aren't going to give you a real wide bandwidth in a 4th order bandpass box.  I'm not familiar enough with BassBoxPro, but I would strongly encourage you to try entering in the parameters again so you can get an idea of what kind of frequency response you are going to get.  Maybe Joe X can help you with that.
As far as port area goes, I really like to keep port velocity under 22 m/sec with bandpass boxes.  BassBoxPro should be able to show you that as well.  With the amount of power you want to run, its going to take a LOT of port area.
What's your reason for wanting to use a bandpass box vs a ported box?
Builds:
Contralto subs love 4th bandpasses. If people didn't adhere so strictly to numbers and programs they would realize this.
Assuming at least RMS power clamped:
Sealed:
2.2 Ft^3
Ported:
6.0 Ft^3 - 10.0 Ft^3
Port Area:
90.0 In^2
Port Tune:
42.25 Hz
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
2 hours ago, bassaholic said:
Won't let me post other pic of vent size, but it's 9.25 tall, 7.5 wide, and 14 long
You are going to want a lot more port area than that.  The guideline of "16 sq in per cube" doesn't work well with bandpass boxes.    From what I understand BassBoxPro should be able to show you your port velocity, you might want to take a look at that.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 533 Guests (See full list)
