Box design for re 12s
just got 2x v1 re sex 12s thinking about doing a 4th order box or regular slotted box
im going to power them on a aq2200.(i know there rated 600rms)
thinking box tuning 32 ish hz since there fs is 25hz
going in back of a 4 door pickup so max 30 deep 48 across 40 high
any input on is great thanks
theses are subs spec
https://www.sonicelectronix.com/item_27312_RE-Audio-SEX12D4.html
Subwoofer Series
SEX (RE Audio)
Subwoofer Size
12"
RMS Power Handling
600 watts
Voice Coil(s)
Dual
Impedance (Per Voice Coil)
4 ohms
Voice Coil Diameter
3"
Sensitivity
86.1 dB
Xmax (millimeters)
18 mm
Subwoofer Design
Round / Circle
Main Cone Color
Black
Woofer Composition
Dual Composite 2-Piece Cone
Woofer Surround
Rubatek Foam
Magnet Structure
Triple Stacked
Subwoofer Grille
No
Re-Cone Kit Available
No
Recommended Enclosure Specifications
Recommended Enclosure Type
Ported / Vented
Sealed
Minimum Sealed Box Volume
0.75 cubic feet
Maximum Sealed Box Volume
1.0 cubic feet
Minimum Ported Box Volume
1.5 cubic feet
Maximum Ported Box Volume
2.0 cubic feet
Top-Mount Depth
7"
Cutout Diameter
11-1/4"
Shallow Mount Installation
No
Electromechanical Parameters
Free-Air Resonance (Fs)
25.1 Hz
Equivalent Compliance (Vas)
72.9 liters
Total Speaker Q Value (Qts)
0.44
Electrical Q Value (Qes)
0.49
Electrical Resistance of Voice Coil (Re)
2.8 ohms
Mechanical Q Value (Qms)
4.5
Efficiency Bandwidth Product (EBP)
51.22
  • Who's Online   0 Members, 0 Anonymous, 3078 Guests (See full list)
