kickerman Posted April 29, 2008 Report Posted April 29, 2008 how is it done? (how do u wire it?) 18" mmats juggernaut rf t10001bd alpine h/u
Stephen Posted April 29, 2008 Report Posted April 29, 2008 they have to be made to be strapped they usally have a master/slave switch and the 2nd amp takes the settings off the first amp. you run rcas off the master to the slave. Also there is a piece of speaker wire that links the 2 amps and the + output comes off one amp and the - off the other. This might not be true for all amps some are different. you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Torres Posted April 29, 2008 Report Posted April 29, 2008 not all amps can be strapped. make sure yours are able to be strapped if you try to. hifonics has a module where you can wire...i think up to 5 amps and link em together tho
ALPINE408 Posted April 29, 2008 Report Posted April 29, 2008 not all amps can be strapped. make sure yours are able to be strapped if you try to. hifonics has a module where you can wire...i think up to 5 amps and link em together tho not true!!! any amp can be strapped just not ment to be all you need is a way to 180 "phase" out one of the amps Have you ever had your woofers blown?
kickerman Posted April 29, 2008 Author Report Posted April 29, 2008 well i have a smaller amp with the rca output. its a smaller amp than the one i want to strap it too so can i have my rcas go into it and then out throught the out put and into the next amp and get more power? 18" mmats juggernaut rf t10001bd alpine h/u
kickerman Posted April 29, 2008 Author Report Posted April 29, 2008 not true!!! any amp can be strapped just not ment to beall you need is a way to 180 "phase" out one of the amps how do i do that? 18" mmats juggernaut rf t10001bd alpine h/u
ALPINE408 Posted April 29, 2008 Report Posted April 29, 2008 well i have a smaller amp with the rca output. its a smaller amp than the one i want to strap it too so can i have my rcas go into it and then out throught the out put and into the next amp and get more power? ya you cant do that! if you strap an amp it has to be the exact same amp sell the small amp both can not be used Have you ever had your woofers blown?
kickerman Posted April 29, 2008 Author Report Posted April 29, 2008 ok thank you 18" mmats juggernaut rf t10001bd alpine h/u
