icedragoneer Posted August 10, 2017 Report Posted August 10, 2017 hey all whats going on i seem to be having some serious issues ive been putting systems in for about 15 yrs (on the side) i always did my own when i was younger and now im doing them for my son ive installed 6 pairs of subs now and blown them all ive made sure not to go over rms power on the subs each time the first set was quantum audio q3000 at 1000 watts rms each on a soundstream amp doing 2000 watts rms at 1 ohm and subs were in 1.5 cu. ft. ea. got about 2 weeks out of them the next set was alphsonik subs doing 1200 watts rms each got about a month out of them so i think its the amp so i get a different amp the ppi black ice 7000 rated at 2300 watts rms at 1 ohm got about 1 week out of subs the gains on the the amp were never above half way up and bass boost up about a quarter i am running 1/0 wire from battery to amp (with inline fuse) also have big 3 done in 1/0 wire also i have never had this much trouble with blowing subs can someone plz give me some advise thanx
Wishuponasub Posted August 10, 2017 Report Posted August 10, 2017 How did you set the gains? You may be introducing a hell of a lot of distortion. What size subs? It may also be the enclosure. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
Mitchaford Posted August 10, 2017 Report Posted August 10, 2017 Bass boost should be at zero. If you're using that gain knob a little too much then you could be introducing some clipped signal. What size are those subs? How are they blowing? Surrounds ripping off? Burnt/Wound coil? If that amp is a SS T series 2k then you could be sending some dirty power. I had one of those amps couple years back right when they re-cased them. It was ok for when I started out but it gave me issues. For those subs that amp should be fine as long as you keep it clean. 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
icedragoneer Posted August 14, 2017 Author Report Posted August 14, 2017 i dont have all the good stuff i just put the gains at half and the subs are 12in. in 1.5 cu. ft. each i think its blown coils
Mitchaford Posted August 14, 2017 Report Posted August 14, 2017 10 minutes ago, icedragoneer said: i dont have all the good stuff i just put the gains at half and the subs are 12in. in 1.5 cu. ft. each i think its blown coils You could have worse man it's all good. Do you know what head unit you have? Finding out at what volume your HU distorts is key. What about the settings on the HU? Could have the bass boost up on that and that would cause a lot of dirty signal. 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
ShadeTreeMechanic Posted August 14, 2017 Report Posted August 14, 2017 Welcome to SMD! Clipping kills subs. When I smell mine get stinky, I turn it down a little. Gain at half way is a shot in the dark. Find someone with an O-Scope or DD-1 in your area to see if they can help you set your gains. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
3vil Posted August 15, 2017 Report Posted August 15, 2017 I'm guessing you melted/slinky'd the coils? Is the box ported, and if so did they start to smell after wanging on em? Hows the voltage look in this rig? I agree with the others that you're just blindly guessing where to set the volume, bass boost, and amp gaim.
icedragoneer Posted December 16, 2017 Author Report Posted December 16, 2017 i found out that he had a faulty amp guys so thanks for all the help so now have a precision power ice 7000 on 4 alphasonic 12s in a compression box got the big 3 done with extra battery
