I'm having problems with my sounds
So I have a 2008 Toyota Yaris sedan base model I installed 2 JL audio amps the JX series 400 watts for voice and 1000 watts for bass and an audio control epicenter I have alpine type r components all around and a type R 10inch woofer. Also I installed an after market head unit a pioneer avh-270bt when I play louder then volume 15 and the sub knocks it cuts out and then there's no bass until I put the volume down. I got a couple opinions from friends and some said to put a capacitor or a stronger alternator. Because I installed an optima red top battery to see if that'll solve the problem but nope any help ?
Check your voltage when it cuts out might be so low the amp turns off.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
2 hours ago, 06RTCharger said:
If its cutting at 15 out of 62? Does ur pioneer go up to 62? If it does, to me id assume ur gain nob on the amp is maxed out?
i believe it stops at 32 but ima check that out thanks
