Electric upgrade advices
Not sure what your question is. Copper is a type of metal. Do you mean copper to steel or zinc or lead?
Pioneer 80PRS
Thanks man. I am going to install the second battery, so I needed some advice for ground, as my last amp got fried on the negative terminal, I guess the contact to the body frame wasn't solid.
This time, I ran sky high 0 gauge from the starting battery to the secondary batt on the trunk, and ground the second batt to the body frame of the trunk. I got 2, 300 amp fuses, close to each positive terminal of the two batteries, and two fuse distribution blocks (150amp - 0 to 2 4 gauge) for my amplifiers, I'll connect the negative of the distribution block, directly to the battery. Does that seems ok to you?
  • Who's Online   0 Members, 0 Anonymous, 5077 Guests (See full list)
