Unexpected Audio Build 2007 crew cab silverado
Mine didn't line up right either. I'm going to give them a call today. The plastics don't line up correctly
Team Bass-Hz
OK so i got the driver side seat back in and discovered a great trick. If you just dont add the extensions hooks on the back of the seat you get the rear seat to fold down when the bottom of the seat is folded up. All the more arguement to building your own if you have access to c channel. shitt like 8 2 inch peices and your done boom bam bolt it down. im not putting in the passenger side until i know if this amp is going back or not...
Secondly, does anyone know how to fix the pouches on the back of the seats?
I believe that plastic rear panel comes off.  Then you can pull the pocket tight and secure it with glue/staples/etc.
IG @walledsonic
If you don't use the seat hooks be ready to be annoyed with a ridiculous amount of noise from the seats
Team Bass-Hz
Yes I thought about that. I emailed LMI to inform them of misalignement and hopefully the can send me correct peices. However I figured maybe I can stick some double sided foam tape stop the vibration and stop the noise as well.
When I pop the plastic off will the other leather be stapled or will it all come loose
Ive seen inside other seats before, and normally there are springs running from left to right, gripping the leather and keeping it taught.
IG @walledsonic
ok so i was able to sell my kappas to a buddy of mine. so now the real question is should i go hertz esk or dsk line. or Focal expert but not the flex cone i can get a full set of focals for about 429
