Question about air movement for Hairtricking
Setup looks clean.
I grew up on mini trucks....always loved Space Cabs.
Upgrade those wheels and give that paint a good polish/wax and you're money.
2010 Accord Sedan
XS D3400R
Clarion HU
Sundown mids and highs
Incriminator amps
Incriminator Lethal Injection 12"
Welcome and nice build, click the following link for song info:
https://www.stevemeadedesigns.com/board/forum/19-tunez-all-things-music-related/
Pioneer 80PRS
45 minutes ago, twalker182 said:
Setup looks clean.
Thanks! I'm looking around for wheels. Not the easiest to find either 15's (that was stock) or 17's (what I wouldn't mind putting on) that have a bolt pattern of 6x139.7. As far as paint goes, it has a little rust in some areas (it's almost 30 years old and spent the last 6 years in a field, I don't blame it), so I'm actually considering plastidipping it. Not just a couple of $5 cans from AutoZone, but like a $700 kit with a layer of pearlescent over it. Going to see how it all ends up going, but should have both of those accomplished before Thanksgiving.
Thanks and thanks again! I'll check it out, appreciate it.
Check your local Craigslist for Escalade or Tahoe wheels.
2010 Accord Sedan
XS D3400R
Clarion HU
Incriminator amps
Not a ton of options in the area, plus they're generally 20's when looking them up. But what I've found I like the most are Toyota TRD's. There are some nice ones in the area, but dropping $600 on rims is not super fun.
Its halloween time. Go get a furry mask from walmart.
Actually, not a bad idea haha
so a couple points..
typically the lower you tune the easier the subwoofers can physically match the amplitude of the signal given by the amp, so basically more excursion. more excursion = more air being pressurized inside your cabin = hair trick. HOWEVER.. the tuning of your box along with fs of speaker etc. will determine which freq your subwoofer/box is able to match that wave the best. long story short if your box is tuned to 40hz play a 40hz test tone and chuck some power to it to see what she does. if it doesn't hair trick you just need more power to get those things moving!!!
btw 4000w on 4 15s walled should be enough for a baby hair trick. SHOULD be.
welcome to the forums bud!
I took your advice, grabbed my dad's old dB Drag disk to roll through frequencies, got it in the forties and cranked up the gain. Looks like I can do basically what you said- a baby hair trick. Appreciate the hospitality!
44 minutes ago, 06RTCharger said:
I know theres a thread about songs that hit bass hard. Forget what its called. Theres a music area tho somewhere on the homepage
I found the music area on the forums, gonna look around that for a bit. Thanks man.
