Crossover on supertweeters?
Carlos Tj
Hey whats up fellas? I want to install some supertweeters in my setup but my question is. Do I need to use a crossover with those? Ive heard that theres no need for a crossover and others say you need a passive crossover. What is the best way to install them? Im going to install directly to my headunit for now while I save up for am amp. But do I or not need a crossover?
2005 Dodge Magnum
Kenwood DNX573S Double Din
NVX Big 3 Kit
NVX 0 Gauge Cable & speaker cable
XS Power V3100 Battery
Iraggi Alternator 320A
3.5" NVX Speakers
6.5" Incriminator Audio Components (just mids)
6x9" NVX Speaker
MVPA4 Amplifier
(2) 12" NVX VCW Subwoofers
XPLD3K NVX Amplifier
YouTube Channel
@CarlosTj664
yes every tweeter needs a crossover/ high pass filter even super tweeters, if not it wont sound right and will get damaged by the lower frequencies. look up your tweeter and check the spec on it, it should say what ranges of frequencies it should play and where it should be crossed at.. you can go with a passive crossover or you go with an active crossover.
the active crossover is best to use because it allows you to have more control of all your speakers frequencies. but it will cost more because those speakers will require there own dedicated amp/ channel. and for best results you will need a digital sound processor / DSP.
With passive crossover you can only set your frequencies with what is giving to you on the crossover. another con about using a passive crossover is that you will lose power output. for example lets say 50 watts is going in to the passive crossover the output will be less than 50 watts i'm not sure how much is lost. but it wont be the same vs the active crossover where you wont have that issue.
if you want more detail read this link: https://www.crutchfield.com/S-DO1B0JnJp4p/learn/learningcenter/car/crossovers.html
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
You think it would be appropriate to use my headunits crossover? The settings on my headunit are very detailed and can do a lot with it. I have the Kenwood DNX573S. Also could I just power it off the HeadUnit would it be enough to make it sound decent.
2005 Dodge Magnum
NVX Big 3 Kit
3.5" NVX Speakers
6x9" NVX Speaker
MVPA4 Amplifier
YouTube Channel
@CarlosTj664
The passive crossover is a safety mechanism if nothing else.  You can then set your headunit crossover higher than the passive crossover frequency.  Then, if you ever turn the head unit crossover off (for whatever reason), you wont blow them.
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 1164 Guests (See full list)
