Nishinga Posted September 20, 2017 Report Posted September 20, 2017 I did an install in a friends vehicle about a month ago and hes starting to have problems, since im now married to this project I just wanted to have someone double check what I did because Im trying to diagnose the problem over the phone and am starting to second guess myself. The setup is: A older JVC headunit - front/rear RCAs to a NVX 800.4. (125x4 @ 4ohm) Front left and right channels to a 8ohm Crescendo 6.5- to a 8ohm Crescendo FT1 crossover - to a 8ohm Crescendo FT1 in either front door Rear left and right channel to a 4ohm Crescendo 6.5 in either rear door. The high pass is set at 80hz and the gains are set properly with a DD-1. The problem came up because the amp kept going into protect. After a while of diagnosing on the phone the end result is that we think the FT1's and/or the crossover are blown. I also found out that the radio was turned up a "few" clicks past the clipping point, which is what im assuming caused the problem. I was told that the tweeters "weren't loud enough." I assumed FT1's on that kind of power would be ear piercingly loud. So thats where im starting to second guess that I hooked everything up right. Thanks for taking the time to read through this. If there is a problem with something I did please let me know. If everything is right and you also think that pushing the radio volume past clipping caused this please let me know also. At this point I plan to replace the crossovers and recone the tweeters and be more adamant about not going past the clipping point on the radio volume.
06RTCharger Posted September 20, 2017 Report Posted September 20, 2017 Looks like u got 125w going to each rear speaker, and 60w going to each of the four front speakers (62.5 to each mid and 62.5 to each tweet using a passive crossover) Maybe thats why he felt it wasnt loud enouch.
8ten8 Posted September 20, 2017 Report Posted September 20, 2017 As per manufacturer specifications, that amp doesn't see 8 ohms. So... $$$
Nishinga Posted September 20, 2017 Author Report Posted September 20, 2017 22 minutes ago, 8ten8 said: As per manufacturer specifications, that amp doesn't see 8 ohms. So... $$$ The amp should see 4 ohms with the 6.5 and tweeter wired in parallel with a crossover in between. Correct?
8ten8 Posted September 20, 2017 Report Posted September 20, 2017 I read your original post wrong. So yeah, seems your wiring is correct. Maybe check your grounds
