77-AUDIO Posted October 2, 2017 Report Posted October 2, 2017 Well I just picked up some new subs and a bigger amp. New equipment 2 MMATS Procast 12" dual 4 ohm 1 MMATS MPA-2000.1 amp Orion 0 gauge wire kit. box will be 3.25 net, 6" port. https://imgur.com/a/sJIxG PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
WalledSonic Posted October 2, 2017 Report Posted October 2, 2017 Nice man. Do you think a single 6" port is enough for (2) 12s? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
77-AUDIO Posted October 3, 2017 Author Report Posted October 3, 2017 For the Low tuning that I want 32.3 hertz, and the box is only 3.25^3 net I have 8.7" of port per cube (port area is 28.26"^2). I should be fine on the port area. I like the low tuning and the flex more than the numbers. but I do like the numbers also. Box is 17" tall, 37 wide, 14 deep. sub up port up. ports 18" long with a double face the port will have 7" of external port. gross box volume is 4 cubes. And whats a good site for pic hosting that you use. I have some pre build pics to post. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
77-AUDIO Posted October 3, 2017 Author Report Posted October 3, 2017 New equipment going in soon. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
