wheel offset vibration?
Recently reconditioned a set of alloy wheels I got for real cheap. I bought them since I needed new tires and didn't want to get new for the steelies I had on. The wheels I reconditioned were from a '09 subaru forester- 17"x7 offset +48 and my wheels were 15" with an offset of +55. I bought nice tires for them (BFG) and dropped the car off at the shop for mounting/balance/alignment. Ever since then, Ive gotten a vibration up past 55mph on the highway; I can feel it in the steering wheel and pedal.
I didn't think the 7mm offset would make much of a difference, but could it be causing this vibration? provided that I didn't lose a weight...I'm about to buy spacers with extended studs to correct it but I'm not sure if it could be causing this.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
If your hub is square and the wheel is square (both items undamaged), then the amount of offset shouldnt matter.  A wheel is a wheel.  The overall vibration limit is a product of the effective off-center mass and the distance of that mass from center.  Much like torque actually, since its a force.  The wheel is either damaged or unbalanced.  Or your alignment is off.
IG @walledsonic
I didn't think it could be, but I wanted another opinion...thanks man! Im gonna take it to the shop and ask if they can re-balance them. I also noticed that the tires were over-inflated by 10 lbs. each so I kicked them down to recommended
