WalledSonic Posted November 26, 2017 Report Posted November 26, 2017 I measured the voltage output at the sub RCA terminals on my head unit, 1.437 and 1.407 volts. I know its only 2% difference, but if you bridge the channels together, im wondering if the voltage value steadies out and balances, and if there are any negative effects. Is this a common practice if the channels are not perfectly balanced? I know some ppl use a DSP, but thats not the topic. EDIT: i have 2 amps, so i was going to use a channel per amp. With a mono amp, the signal is handled in the amp. EDIT EDIT: i guess it doesnt matter if both are set with a DD-1, huh Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
reedal Posted November 27, 2017 Report Posted November 27, 2017 in your case, upon gain-matching the amps to matching outputs, it shouldn't matter unless the voltage on each side doesn't change at the same rate as music is played. But if equal RCA output from the HU is what you're looking for, it could be your HU settings. You have the 80PRS correct? there's a setting for mono/stereo sub-out in the audio settings menu, somewhere in the same area of adjusting the levels. Are you set to Stereo? Auto T/A done? I can't remember if you're able to adjust the L/R sub levels like you are mid and high, but that could be the reason for the difference you see. Or I could be completely wrong about your HU/settings. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
WalledSonic Posted November 27, 2017 Author Report Posted November 27, 2017 Thanks for the input. Yes, its a PRS but its set to mono in the settings. Had trouble setting the SSF earlier after setting with the DD1. Used Damores -5dB track and set the amps at 70V. Then for SSF testing i used Got160s -4.5dB tracks (only ones i have on that drive). 40Hz track was giving me ~70V on both channels while the 23Hz track was giving me ~70V on L channel and 59V on the R channel. Gonna do full testing at the head unit tomorrow with a bunch of tones to see if my channels are even. If they arent even, i may just use the single good channel and split that to the amps. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
reedal Posted November 27, 2017 Report Posted November 27, 2017 That's no good. was the 70/59v with the SSF all the way down on both amps? I'm sure it was, but I ask just for process of elimination purposes. I would say try swapping the left/right inputs to each amp, see if it follows the RCAs, or if it stays with the amp that originally output 59v. if it stays with the amp, it's the amp, but if it swaps, HU for sure. Now you've got me curious if my RCA outputs are equal on mine... SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
WalledSonic Posted November 27, 2017 Author Report Posted November 27, 2017 I'll be pulling the HU and testing in about an hour after I pick up some beer. I will report back the findings. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
WalledSonic Posted November 28, 2017 Author Report Posted November 28, 2017 Alright, here's the voltage straight out the head unit with a Got160s -4.5dB test tone at: 40Hz Left: 1.872 Right: 1.913 23Hz Left: 1.872 Right: 1.912 About 2% off from each other. Then I tested the voltage at the amps: 40Hz Left: 73.5V Right: 69.5V, but I matched this one to 73.5V. 23Hz Left: 72.5V Right: 72.0V This isnt the difference I was seeing last night, but thats good. Maybe I had a wiggly connection somewhere. Then I set my SSF to 52V at 23Hz, which is about 0.7 of the 73.5V reading at 40Hz. So the 2% difference I guess doesnt really matter, but I think I'm going to leave the left channel unused out of the HU and split the right channel to the 2 amps so that I know the amps are always getting the same waveform. Probably unnecessary, but it would be nice knowing the amps are seeing the exact same signal. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
