Phillip Klocko Posted December 13, 2017 Author Report Posted December 13, 2017 thank you all for your help.. thats why i love these forums you people are awesome and very helpful!
Wishuponasub Posted December 13, 2017 Report Posted December 13, 2017 Yep the multimeter is the way to go. I also am not proficient in using one but every time I have to do something I consult with YouTube or Google to make sure I am on the right track. It can seem overwhelming with all the settings and whatnot but just break it down to the task at hand and you will be fine. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
MADVIBES Posted December 13, 2017 Report Posted December 13, 2017 its definitely not your alt, if it was your truck wouldn't remain running after you jumped it. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
SkarredSierra Posted December 13, 2017 Report Posted December 13, 2017 You said the batt u have was only a year old? No warranty? Also if u have a walmart near u they sell a super cheap battery for 50 bucks that comes in a small variety of cranking amps with a 1 year warranty. It may not be the best but will work till u save for somethin better. At least ud be able to start ur truck. Just make sure ur secondary batt is still good. Otherwise you will have the same issue.
SnowDrifter Posted December 13, 2017 Report Posted December 13, 2017 Couple questions: - What's your charging voltage? Check at the alternator and again at each battery - How quickly does the battery drop to 10v before continuing to fall off? ---What happens if you disconnect your secondary battery? What's the voltage v. time behavior of each? - How are your batteries wired? - Do they have removable caps such that you can see each cell? - Have you performed a parasitic draw test? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
