Port Placement
Jhunt94
See the source image
I have a 2017 F150, and I am currently planning on putting two SA-6.5's under the rear seat. The box will be on the passenger of the vehicle. Right now I'm not asking for help on box size, tuning etc. but I am just wanting some input on port placement. I've always seen people talk about porting to the drivers side,  but in this case I'm not sure if it would be best in case I store something under the seat. I can do it any way (forward, passenger side, drivers side), just trying to figure out what would be best. Thanks
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Side fire allows you to have a long port without bends so you can get lowwww without making the build process complex.
IG @walledsonic
any particular side?
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Do you drive alone more often or normally with others in the truck?
Is that a 4 door or a third-door extended cab (looks like 4dr)?
I'd probably load off the passenger side door, but I'm tuned in for other people's opinions.  I'd imagine that loading off the passenger door would sound better to the driver's ear, but I dont know for sure if thats accurate.
IG @walledsonic
I would down fire the subs to get a load on the front of the cone and port toward the passenger door if the box is going to be closest to that door, if the box is shifted toward the drivers side then I would port towards the driver side rear door.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
@WalledSonicIt's a full four door truck, and most of the time it's just me or maybe me and the girlfriend. I didn't really think about that @MADVIBES, I would probably get a little more out of it if I face the subs down. I should be able to do that.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Good info.  For my own knowledge, why would you desire to port on the drivers side door for a small box?  Something about loading the port or reflecting the wave off a wall/door in close proximity??  Perhaps the same reason why a non-sealed-off trunk setup would want to port against the trunklid?
IG @walledsonic
using the side doors is like facing your subs off the back wall of a trunk, it helps with phase issues, ideally you could with a little creativity face both the subs and port towards the rear wall in this set up. make sum magic happen
also with this size underseat box you can do a 1/4 wave transmission line
interesting. I've never attempted to build a transmission line box before
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 1101 Guests (See full list)
