llaammaa Posted December 16, 2017 Report Posted December 16, 2017 Assuming that the box and everything is setup right what would be better 2 Rockford p3 15's on 1500 watts or a single Rockford T1 15 on the same power?
Markous Posted December 16, 2017 Report Posted December 16, 2017 Cone area is king. '07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I On 5/21/2015 at 7:07 PM, boom50cal said: of course he gives no fucks. it's a ford ranger. only bad mother fuckers drive ford rangers
Triticum Agricolam Posted December 16, 2017 Report Posted December 16, 2017 If you have the space, run as much cone area as you can. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
icedragoneer Posted December 16, 2017 Report Posted December 16, 2017 2 subs are always better than one as long as the power is there and clean
ShadeTreeMechanic Posted December 17, 2017 Report Posted December 17, 2017 My OCD won't let me run an odd number of subs. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
