Port location problem
77-AUDIO
Vehicle 2017 kia soul.
Box 5 cubes net. Port area 50" tuned to 30 subs up.
Box is 39 wide 25 tall and 14 deep.
I want to do port back. But should i do it at the top or at the bottom.  Port will bend either way.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
How much power are you running?
I'm not sure how you would layout a port running along the top without it getting in the way of the subs.
Builds:
wheres 412cvx he knows a thing or two about moving ports
naw but really. if i remember what i'm doing, you're running 2 extra baffles, and planning a 4x12.5 port@26 inches long, or so. Seems like port at the bottom would be the most simple.
i'm a big round port fan, so you could do a rear exiting side port with two 5" ports, at 16" long or so. would require 2 90's but PVC is cheap, and i'm too dumb to make cut sheets for slot ports lol.
Port is L shaped. Box is 14" wide where the subs sit. Have enough room to put the port between the subs.
Port is designed to fit between the front and back of the box.   Its 12.5" and the it bends and will be attached to the front of the box.
Thats where the L shape comes in.
Power is a mmats mpa-2000.1 wired to 1 ohm.  Stock electrical with a factory 130 amp alt.
PPI dbl din
DC Level 3
DC audio 2.0k
  • Who's Online   0 Members, 0 Anonymous, 1352 Guests (See full list)
