Sloppy hamfingers Posted January 5, 2018 Report Posted January 5, 2018 The 80 prs has been out awhile but seems like the best single din put out in awhile, I’m definitely no expert so don’t flame me and say I’m a moron just yet. Lol. I’m just wondering if the newer $300 pioneer double dins are more show than sound compared to the prs, I’m sure you could debate pros and cons of both but I’m just wondering if the prs sound is a lot better than the double dins, I like the big screens and options but mostly the look in how it fills up the dash, but I’d settle for the single din 80 prs if it’s 10 times better for quality. I’m choosing for now to run a pair of 6.5 components without an amp, my two 12’s are gonna be running off a alpine 500 mono, just like to hear opinions on what’d be the better decision.
WalledSonic Posted January 5, 2018 Report Posted January 5, 2018 I dont think the same components are used from the 80PRS in any double din model. People that have the double din and want SQ just add a DSP Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ShadeTreeMechanic Posted January 6, 2018 Report Posted January 6, 2018 The 80 PRS has separate Bur-Brown 24 bit D/A converters for each pair of outputs along with built in DSP and 5v pre out make this one of the best sq head units that is still available. I bought mine for the DSP and was surprised how much better it sounds than the JVC I took out. There really is a difference. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Sloppy hamfingers Posted January 7, 2018 Author Report Posted January 7, 2018 I’ve always heard if it sounds too good to be true it probably is, but I’ve found a 80prs brand new online for $113. If I order it I will pass on the knowledge, damn good deal tho I thought.
ShadeTreeMechanic Posted January 7, 2018 Report Posted January 7, 2018 15 hours ago, Sloppy hamfingers said: I’ve always heard if it sounds too good to be true it probably is, but I’ve found a 80prs brand new online for $113. If I order it I will pass on the knowledge, damn good deal tho I thought. Wow! Let us know, for that price I would buy another. Maybe they are referb? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
