Replacing caps in an amp.
BMS
My local shop is going to replace the capacitors in my amp but i have to supply them what brand should i buy? on ebay preferably. 1000uf 200wv (200v)
Nichicon
Samwha
Samyoung
There are others though.  Check out the Amp Guts subforum too
IG @walledsonic
OK why do you need the shop to replace them?  Replacing caps in a amp is easy peasy if you have a soldering gun & desoilder to take them out.  A picture of the caps would be helpful so we know what size they are so we can help alot more.
Here is some from Parts Express that meet the values you gave.
https://www.parts-express.com/Search.aspx?keyword=1000uf 200v capacitor&sitesearch=true
73456w9vbwevsdb
sodtbsorutnvsd
sdtuspdun sd d
f gsdfiusd gdf n
I just found a Nichicon that works they are 25mm dia. the shop is only charging 25$ because they know what the problem is (no diag) i can't solder worth crap. they also told me the thyroidal coils are dark and the glue is bubbled which i didn't notice before.  Guess i killed the ct at 3/4 ohm.
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
