BMS Posted January 21, 2018 Report Posted January 21, 2018 My ct sounds at7000.1d (which blew up) is being out burped by my audiopipe apcle1500.1d. 7k vs. 1.5k. Even if the audiopipe does handle the 3/4 ohm load better there is something way wrong with the ct right.
MotorCityFats13 Posted January 21, 2018 Report Posted January 21, 2018 do you have the electrical to back up a 7k amp.... if you dont then this could make more sense
ChevyBoy95 Posted January 21, 2018 Report Posted January 21, 2018 Either the amp is blown (or malfunctioning) or that amp should literally stomp the shit out of that 1500. If the gains are set correctly and everything is wired right, of course (double check everything no matter how trivial). edit: and if you electrical can only handle 1500w, putting a 7000w amp on the same electrical will yield about the same results. So just make sure you have like a high output alt and a few batteries to feed the 7k. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
DTS909 Posted January 21, 2018 Report Posted January 21, 2018 Whats your electrical? VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
