Jay2552 Posted January 30, 2018 Report Posted January 30, 2018 02 Honda Accord. Box will be built facing in and sealed off. I am getting a SQ2200d and a hdc312, but I’m not sure if I should run two off that amp. Wired at 1ohm.
audiofanaticz Posted January 30, 2018 Report Posted January 30, 2018 You could run 2 subs on the one amp, they would need to be dual 1 or dual 4 ohm voice coils to wire it to 1 ohm at the amp. If your only running 1 sub to the amp or you want to buy 2 subs and 2 amps you would need to order dual 2 ohm coils to wire it to 1 ohm on each amp. Those subs would take a sq2200d each without problems. 2 subs 2 amps and get banging!
