Terminal bolt material
3 hours ago, meade916 said:
it won't make one bit of difference...
Copper is only 2nd best...so if you are gonna play the copper game, you might as well be a baller and go with silver terminals.  :D
Stainless works fine ESPECIALLY at such a short distance like using a bolt for a terminal.
Why not cool your box with ln2 and run superconducting cables ?
22 hours ago, Broke_Audio_Addict said:
Id use aluminum bolts simply because of the risk of galavanic corrosion occuring between the steel and aluminum.
That only happens in the presence of an electrolyte, not with dry contact (assuming it doesnt get wet).
