if a sub says impendance 2 ohms then does that mean i have to get a amp that is 2 Ohms???im new to this....i plan on getting a single 12 inch alpine type r or a single 12 inch kicker cvr...which amp will be best for these subs??and which sub is gonna be louder???THANKS!!!
ohm is resistance so
type r's have two voicecoils wrapped together so each coil (positive and negative on each side of sub) should read around 4 ohms or 2 ohms depending on which model you get
same goes for kicker using dvc
personally ive seen ALOT of type r setups that are very loud
id suggest any amp that puts out 5-700w as type rs are infamous for taking more than they're rated
never liked anything kicker
ie: (1)12" alpine type r dual 2 ohm powered by rockford fosgate t500-1bd would be nice
should the amp be 2 ohms????...do amps have ohms??...i dont know anything about this stuff
ohms are a measurement of resistance, the less resistance the more power
so most 1 channel or mono amps produce power from 1-4ohms, the lower the ohm the more power
the amp i suggested puts the most power at 1 ohms, so u need a dual 2 ohm type r cause it will walk all ofer that kicker
if your kicker is a 2 ohm dual voice coil sub, wiring just that 1 sub to your amp will give you either a 1 ohm load, or 4 ohm load. 1 ohm load wired in parallel, or a 4 ohm load wired in series.
a 1 ohm dual voice coil sub will give you a .5 ohm load wired in parallel, or 2 ohm load wired in series.
4 ohm dual voice coil sub will give you a 2 ohm load wired in parallel, or 8 ohm load wired in series.
see the pattern that follows?
Get an amp that is "2 ohm stable" which is practically every amp made
I would get a Kicker 750.1 to start off on that. its 2 ohm stable so you can use your R
or you can get a Hifonics amp and it is 1 ohm stable.
we need a sticky on this
cause there have been more than one of these threads around here lately
also krannyman u cant get 2 ohms out of a 2 ohm dvc sub
he needs 1 ohm or 4 ohm
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I believe we did have some type of sticky in the subwoofer/enclosure section...... but I could be wrong.
EG Limo
Chrysler 300's Stretched
Lambo Doors
20" Rims
oh oops, didnt know it was a dual 2.
I suggest a Hifonics TXi 7508 750rms at 1 ohm
off topic, but he has to bump his electrical up a little bit. 700w can take a toll on a crap electrical
  • Who's Online   0 Members, 0 Anonymous, 7224 Guests (See full list)
