Changing the phase settin DOES NOT (obviously) change how they're mounted-it does reverse the signal they are getting 180 degrees. so pos = neg and vice versa. And if the music says "pushed out" the sub will be "sucked in" = reversed of normal phase...
Any help?
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
yea a little so your saying since i got it on reverse that instead of pushing out they suck in when they are suppose to push out and suck in when they are suppose push out sorry :-[
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Yup. BUT!... as long as they do it at the same time as each other they will be ok on output but maybe out of phase w/ ur mids.
As long as the wiring is normal on ur mids, and ur subs are not inverted, normal phase (0 degrees) should be best.
however-If it sounds beteer a diff. way do THAT for sure :D Maybe you have a ghost!
lol one quick question... if i have an inversted sub (i dont just wanting info) and i wire it out of phase (switch pos and neg) does the ohm level stay the same? and if it does why wouldnt it change (dvc subs)
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
i dont think it would change only because a dual 2 ohm sub, is a dual 2 ohm sub unless you change the voice coils out.
true but a dual 2 ohm sub wired in series is a single 4 ohm load... switching pos and neg seems like it might mess something up im my head... unless im thinking about the wrong wires.
well...
If you change polarity on ONE coil only...on a DVC sub you WILL be changing the way THAT sub is hooked up AND any others hooked to it whether series or parallel.
If you have 1 sub in the whole system...and you change ALL coils polarity (+/-, -/+) wether it's 1, 2, or even 4 coils, as long as you swap them ALL (as many coils as that sub has) the ohm level will be the same...it may THEN be out of phase w/ other components in the system, but the ohms/resistence will be the same. a 4 ohm coil is a 4ohm coil whether it is wired +pos to pos+ and -neg to -neg or vice versa...it's only when you run woofers TOGETHER and change one or more voice coils, that will chnage the resistance TOTAL at amp.
Make sense? maybe?
oh so you change all the wires... makes sense. lol i was thinking you only change one for some odd reason
I hope that helped?
  • Who's Online   1 Member, 0 Anonymous, 1527 Guests (See full list)
