was wondering what the difference between rms power and nominal power is
for example im looking at the orion xtrpro sup they are rated at
1250 rms
2500 nominal
5000 peak
plz help when i was in the car audio game they just had rms and peak but then again that was the 90s lol
RMS would be actual wattage made.
In engineering,  "nominal" is used to describe a measurement  (or group of measurements) that matches the predicted value(s) withing the expected margin of error.
More often than not, RMS ratings are not met.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
RMS means the amount of power is required to not damage the sub, nominal means it can handle that amount for a long period without any damage, and peak means that is about what the sub can handle peak wise before it self destructs by either bottoming out or smoking out!
73456w9vbwevsdb
sodtbsorutnvsd
sdtuspdun sd d
f gsdfiusd gdf n
I would say that it could handle 1250w all day long...but probably not 2500.  If it is what I am linking to, it doesn't appear to be built up enough to handle 2500 real musical watts for hours on end...but that is just my opinion.  I don't like how they have those ratings listed as it implies some dishonesty in it.  By 1250 RMS, that tells me it will handle what a 1250 CEA rated RMS watts all day.  To know what kind of amps will do that, look at Ryan Blakenship, BigDWiz or Steve Meade's amp dyno videos.  The AD-1 will help keep the makers honest on the amps and the subs will eventually follow suit.
http://www.orioncaraudio.com/xtrpro-series-subwoofers-/593-xtrpro-104d.html
Orion used to be fantastic stuff but more recently they have started doing the cost-savings made-in-china thing and have lost a bit of their reputation.  YMMV
Orion XTR amplifiers
Skar subs
You might contact Orion and ask them this question.  They have a warranty to honor if they lie to you and say it will do stuff that it can't.
Skar subs
Lots of factors will determine how long you'll be able to play.
Also consider your amp too.
2008 VW Jetta
Team Fi 12
CT 4000.1
CT 125.4
PWX 6.5
80 PRS
EB Flex 2/0
Second Skin
^^^ Build ^^^
