I need a favour from someone who has the ability to punch some numbers into Excel for me to get some T/S numbers for a sub i have.
I followed Tony's video to the T and i got myself some #'s for my Stereo Integrity HST-15 mkII.
I don't have Excel on my computer and don't want to pay $80 to get MS Word and don't feel like chancing a downloading of something that might have a bug in it.
Here are the numbers i got in order as seen in the video above
Cone diameter - 12.25"
DC resistance - 0.8 ohms (coils in parallel)
IM/SG Probe resistance - 0.14 ohms
IM/SG connected to driver max. impedance - 18.6 hz  & 16.4 ohms
@ 7.7 ohms below - 14.6 hz
@7.7 ohms above - 22.8 hz
Weight added - 190.3g (master lock and small dab of blue tack)
Peak impedance with weight - 16.1 hz & 15.3 ohms
Pretty sure that's all the data required, if i missed anything let me know and i'll get it
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
Excellent! thank you SnowDrifter!
Did i do it right? (right value's in the proper fields?)
#'S from SI's website.
Damn, Tony wasn't kidding about the discrepancy between #'s ?
Edited by Markous
You might have to tweak your low and high frequency @ impedance measurements as the calculator wants you to use at 3.662 ohms vs the 8.7 ohms you were using
You mean the fields labeled f1 & f2? retake and input the numbers found at 3.66 ohms above and below instead of 7.7?
Thanks again man, it is much appreciated!
this is what it came up with with the new data input
Just dropped the digits into winisd pro and . . . . . :unknw:
Getting a QTS,QMS,QES  consistency error, sure looks to me like input the correct numbers in the right input fields, no?
