Sundown SA 10s
Daddy_
Could JoeX or someone design me a box for 2 10" Sundown SA's on 1500-2000RMS. Looking for the box to be tuned to 32 hertz and if I have the room dual chamber box. Specs are below
32W x 16H x 18D can do 20D if needed but prefer 18D
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
Anyone?
Yes if not then one chamber is fine
Nothing wrong with subs sharing air space at all. I can design you a box. Where do you want the port? Slot port to the side ( shared space) or middle ( woofers sperated).
Port to the side is fine. 32w 16h 18d tuned to 34 hertz
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Is 2.2 net cubes ok. Dont the SA 10s need 1.25 per woofer so 2.5 total? I also decided that 32hertz might to low and I would never play that low so instead could you do 34 hertz? Also what if I gave them 1.5 per woofer and 3 cubes total what is the difference between 2.5 and 3 cubes Id hear?
I would try...
14.5x30x18
Port- 13x2.75x26 (port area 35.75in²{14.35in² per ft}
Double front baffle
Displacement- subs=.20 , bracing and 45° corners=.12
Gross=3.54ft³ Net=2.49ft³@34.59hz
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
