BassMunky Posted August 12, 2018 Author Report Posted August 12, 2018 Lol can't it flaky. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted August 13, 2018 Author Report Posted August 13, 2018 Bumpp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
lightfoot Posted August 13, 2018 Report Posted August 13, 2018 I have seen this happen before. Unfortunately the only way to fix it is to replace the touch screen panel. they are available at pacparts.com. There is no need to replace the whole lcd, just the touch screen
BassMunky Posted August 13, 2018 Author Report Posted August 13, 2018 Oh that good can just replace the screen chee Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted August 14, 2018 Author Report Posted August 14, 2018 Fml 250 might as well buy new. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
s5300 Posted August 15, 2018 Report Posted August 15, 2018 that looks like some sort of cover.... Did you take the initial out of the box plastic seal off lmfao? If not... I don't want to accidentally have you break your shit... but I want to say hit it with a heat gun for a few seconds and then give it some evenly distributed pressure.
SkarredSierra Posted August 15, 2018 Report Posted August 15, 2018 If it still works just use a plastic blade to knock off any loose or bubbled areas and keep rockin it. If it bugs u enough replace it.
BassMunky Posted August 15, 2018 Author Report Posted August 15, 2018 Oh noo Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
lightfoot Posted August 15, 2018 Report Posted August 15, 2018 18 hours ago, BassMunky said: Fml 250 might as well buy new. what brand of head unit? i have replaced them on multiple kenwood and pioneers and the touch screen panel is only around $60
BassMunky Posted August 15, 2018 Author Report Posted August 15, 2018 jvc 840 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
