RCA's about 2 feet short.
Redid my setup and now my RCA's won't reach whichever amp I mount to the left side of the back of the box. How do I extend them. Will my RCA's lose some input voltage? Probably be easier to run the monoblock I guess since my ground distro block is also on the left side and I have dual grounds going to my amp and that'll make them shorter.
You can get a 1 meter (~3ft) RCA and some female to female RCA connectors and just extend them. You wont notice any difference.
Other thing you can do is if one of the amps has a pass through (through out) RCA connection (RCA output) you can run from that to the next amp. So run the RCA to the right amp and run the through out RCA to the second amp.
