13 minutes ago, KyleRhone said:
what did you end up using as a charger on this?
I just use a die-hard 2a trickle charger rigged on a 12v plug.
 if your planning on using it daily you might want to look at a stronger charger that can double as a power supply. In my case this box is used for fishing and power outages so i get away with a small charger. That die-hard without a choke filter does make a bit of high pitched noise fyi, just so you know.
  • 2 months later...
