BassMunky Posted November 7, 2018 Report Posted November 7, 2018 Suggestions on what 6.5 speaker and tweeter to get. Also what ohm be better 4 or 8 ohm? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
KCK Jukebox Posted November 8, 2018 Report Posted November 8, 2018 Ohm load depends on amp/amps your using and how many your wanting to run. Without knowing that first and knowing what your goals are with the sound
BassMunky Posted November 8, 2018 Author Report Posted November 8, 2018 Loud and clear Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
KCK Jukebox Posted November 8, 2018 Report Posted November 8, 2018 All can be made loud and clear. Ok next step. How many do you plan on running. And How much power. And how will you be setting the crossovers for everything? Passive or active. granted the loudest will be the neos.
BassMunky Posted November 9, 2018 Author Report Posted November 9, 2018 either 1 or 2 echa door sundown 100.4 or 200.4 ctive all the way and whatever manufact specs? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
KCK Jukebox Posted November 9, 2018 Report Posted November 9, 2018 Ok. Going by sky high and droppin hz websites......mclaren sucks. How the hell does neos have lower sensitivity then ferrite. Honestly for the loudness you want look at a different company. As youll be needing 4 ohm mids and tweets. Rockford, ds18, massive, prv and others would be a better choice. And i went from ds18 neos back to rockford. As rockford has been the only mids i can find thatll play crossed over at 90hz cleanly and produce sick midbass.
BassMunky Posted November 18, 2018 Author Report Posted November 18, 2018 Ds ,prv ,or massive? Wanna try something different I have the rf pro right now Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
KCK Jukebox Posted November 18, 2018 Report Posted November 18, 2018 I have a set of ds18 exl neo 8s coming that im going to be trying. They supposedly play down to 80hz so ill be giving them a test
White Lightning Posted November 19, 2018 Report Posted November 19, 2018 A clean, clear, and properly mounted "Mid Bass" driver should have no problems playing down to 70 htz on a 12 db slope. just saying Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
BassMunky Posted November 19, 2018 Author Report Posted November 19, 2018 Ds ,prv ,or massive, McLaren ? Wanna try something different Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
