jrm088 Posted December 30, 2018 Author Report Posted December 30, 2018 ok so i decided to draw the port on the front of the box to see if i could center the subs. i decided to go slightly off center so the sub wouldnt be right on the port.
jrm088 Posted December 30, 2018 Author Report Posted December 30, 2018 subs fit perfect. now to clean my basement and garage. it looks like I've been cutting wood for 10 years with the amount of saw dust in here. fingers crossed she sounds good. time to caulk the inside while i wait for my aeroports and carpet to come in.
jrm088 Posted January 1, 2019 Author Report Posted January 1, 2019 aero ports came in today. i cut them down to size and hooked everything up for a first test before the carpet comes
jrm088 Posted January 1, 2019 Author Report Posted January 1, 2019 everything sounds really good so far. going to do some more tuning tomorrow and figure out where to put the amp. i have literally no more room! Any suggestions?
will77530 Posted January 1, 2019 Report Posted January 1, 2019 How much space do you have from the cab of truck to the ports
jrm088 Posted January 1, 2019 Author Report Posted January 1, 2019 not much. i had an interior trim peice in the way but i cut it out. ill measure it shortly
will77530 Posted January 1, 2019 Report Posted January 1, 2019 I ask because that will also effect your tuning
bcbrassard Posted January 1, 2019 Report Posted January 1, 2019 Floor pan on rangers are gay! I couldn't find a small flat enough section to mount a RF PBR300x4 amp. Under the seat would have been ideal in the 09 ranger i did but used back wall and we had 1 RF 10" Shallow enclosure that fit in the middle ok. In your situation maybe the enclosure? I don't know what size amps your working with?
bcbrassard Posted January 1, 2019 Report Posted January 1, 2019 I looked up the dimensions 12.5" x 2.4" x 10". Doesn't look like you have a space that big on the enclosure. under seat or dash?
jrm088 Posted January 1, 2019 Author Report Posted January 1, 2019 yeah i tried those spots. i have a solution. its the only thing i could think of to create amp space and clear the space next to the port so its aimed at the cab. ill start on it tomorrow
