bmwking Posted February 5, 2019 Report Posted February 5, 2019 17 hours ago, ehall8702 said: My first thought was the vfl, AB has never let me down, but those hippos look like they handle business! Actually about to put 4 of the 6.5 s under my buddies rear seat of his f250 super duty. Was kind of waiting to see how they sounded before i decided. Still on the edge about the single 10, cause 2 vfls would not only look awesome ( i got a thing about shit being symmetrical) but 2 8s have more cone area. Thanx lol, now i gotta go through the pros and cons all over again! if those 4 6.5s are in a ported box to spec, you're gonna be surprised!
ehall8702 Posted February 7, 2019 Author Report Posted February 7, 2019 What do u think about db drive wdx8? "Handles" twice the power of almost every other 8 ive seen. Probably gonna have to settle for one sub at a time so gotta make em good ones. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
ckeeler11 Posted February 8, 2019 Report Posted February 8, 2019 On 2/6/2019 at 6:21 PM, ehall8702 said: What do u think about db drive wdx8? "Handles" twice the power of almost every other 8 ive seen. Probably gonna have to settle for one sub at a time so gotta make em good ones. What does power handling have to do with quality? Look through the 100's of build threads on this site how many used DB drive??
ehall8702 Posted February 8, 2019 Author Report Posted February 8, 2019 Power handling has alot to do when my amp is way over powered, but couldnt find shit about thise db drive subs, no real info on the site so i just went with what i knew was good quality and ordered the vfls will wire em to 4ohm and give em 1k and they should be happy untill i eventually get 2 more. But yeah ur right, even if it can handle crazy power doesnt mean its gonna sound good or last. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
