2017 Ford F250 6.7 Superduty Build Project - Sound system, Front Doors Started - B2 Audio Reference Three Way's Custom Adapter Plate UPDATE 1/21/20 (page 6)
it works GREAT! look at the Banks gauge that i programmed as close as i could (no options for a 37”) I did a conversion on that one. Its just 1mph faster than the trucks cluster. Im positive the dash is the correct number 😎
Follow my Tweet (Twitter)
tried to drop the toy hauler on the truck and it made it sag too much. So i had to get some helper bags. I chose Firestone Ride Rite with air command remote.
Time to start the door speakers FINALLY.
I am glad i thought ahead when i installed these amps a while back.  I made it easy to access the gains and switches etc by leaving enough slack to life the rack up and on to the seat. After i set everything up i will drop it all down in it's spot and bolt it down.
Shown: B2 Audio Reference Class A 4 Channel (Class A/B can be chosen with a switch) on the highs.
B2 Audio Rage 2500.1 on the subwoofers
just messing with the crossover settings.  No, that EQ is NOT what it is going to be. I was just moving it around to see if it made changes when i did so...and it did of course :D
Processing by: Audiocontrol DM810
Power Distribution by: SMD "Split block"
This is what was in the door.
I used my laser and some cardboard to see if the basic shape and cutout holes would work. It seemed to work the first try! That's a first!
Time to take those cardboard cutouts to the next level. I used 3/4" Starboard (HDPE) for the job.
I just had to do a little bit of trimming but it was a piece of cake. Just a small bit of the 6x9 opening was in the way but i took care of it.  You will see it in the video i will upload soon.  I will also put some Second Skin @Second Skin on the panel before the ring is mounted permanently.  I am just stoked all the factory mounting holes lined up first try :D
these are NOT mounted or wired yet! Tomorrow i will get it done.  I had to leave for an important appointment today (Tattoo of course) :D:D
  • Who's Online   0 Members, 0 Anonymous, 2026 Guests (See full list)
