Tribe Called Bass Posted March 7, 2019 Report Posted March 7, 2019 I know this is a silly question but this will save a days worth of rewiring if i don't need to. So i have a bose bypass harness, the harness is wired directly to all of my bose speakers(all being replaced by b2 ref 3 way). Heres the issue though, the leads that come out of the harness are 16-18g wire that connects into a LC7i. The b2 amp pushes out 125.4 @ 4 ohms and 325x4 @ 1 ohm. If i keep the stock wiring, will i be losing power? Or should i just rewire all of it with my big spool of cca sky high 14/16g?
Tribe Called Bass Posted March 7, 2019 Author Report Posted March 7, 2019 Heres the harness im talking about
k58.cross Posted March 7, 2019 Report Posted March 7, 2019 Retracted, I can't do math today apparently.
bcbrassard Posted March 7, 2019 Report Posted March 7, 2019 Solid wiring job. Google wiring wattage diagrams. From what i see on the chart it would be ok, but for my piece of mind on my builds i run new wire and most do. Yes its expensive and time consuming part part of the process in this hobby.
k58.cross Posted March 7, 2019 Report Posted March 7, 2019 It would work. I recalculated square root of 125W*4ohms = 22 VOLTS (not amps). Then 125W/22V it's only like 6 amps. That's not considering impedance rise either. 16 gauge is good for about 12 amps continuous. Playing music you'd only be hitting current spikes periodically. You could wire bigger for future upgrades though. But don't use CCA, go OFC for long distance wiring because CCA has more resistance per foot.
