need help with amp in protect mode
Hi, I'm installing 1 Rockford Fosgate p2 12 which I'm running with a Rockford Fosgate 500x1d wired to 2 ohms. When my bass hits my amp goes into protection mode. I rewired the sub to the box, made sure the ground was good. I'm totally lost on what to check next, any help would be appreciated. Thank you
Do you have a multimeter? check the resistance of the pos/neg speaker wires with them disconnected from the amplifier and verify they are indeed 2 ohms if you are lower than that the amp will go into protect, as it is only 2 ohm stable.
I have used the prime 500 amp and have never had problems, even bought another for my dads bronco.
Any pics of the install would help also
