BT signal cleanliness
I just got my first Bluetooth head unit (pioneer). I’m just curious what volume level I should set my phone to (iPhone 7) to avoid clipping while playing iTunes.  Not running any amps right now and don’t have a dd1, just curious if someone has tested that the phone is clean all the way up or if it varies from model to model? TIA
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
  • 1 month later...
the Bluetooth on my pioneer  clipped at 38 our of 42 on my head unit, as did everything else on it. but im sure that it is different per head unit. I would set it at around 75-80 percent of units max volume, the issue with blue tooth is your S/N ratio drops and is more inherent to noise, I would just test your RCA voltage as this usually clips one or two steps after the speakers and just make sure its not going over what your rated and as soon as it does dial it back one or two notches its going to be all guessing until you get a DD-1 or DMrta / oscope .
2012 Kia Soul
 Infinity reference 6.5's  Coaxials
2x Soundqubed HDS312 @ 32hz (hdx312 waiting on alt)
1x Skar Audio RP-2000 (deaf bonce 4k on floor waiting on alt)
1 x Northstar group 35 front
1x Nortstar SMSAGM220 rear (have a second one waiting on alt)
0 gauge Sky High OFC
BIG 4
  • 3 weeks later...
Thanks for the responses folks, I appreciate the input. Once I get the system started and amps in I will get in touch with my contact who does have a DD1, so should find out for sure at that point.
Subs/Amps: TBD
Test and Tune
  • Who's Online   0 Members, 0 Anonymous, 943 Guests (See full list)
